evmoore
Jan 25, 2017Aspirant
Port Forwarding Problems on Netgear Nighthawk R6700
I've been trying to forward ports on my Netgear R6700. V1.0.1.16_10.0.30 I have an Arris 6183 modem. After playing around for several hours last night I managed to get it to work, but I had t...
- Feb 23, 2017
I managed to get the ports forwarded in the past few ago (finally). Thanks everyone for the assistance.
ElaineM
Jan 26, 2017NETGEAR Employee Retired
Welcome to the community, evmoore
You may use Address Reservation feature on the router if you want those computers to have a static IP address assigned to it.
See the link below on how to configure Address Reservation.
evmoore
Jan 26, 2017Aspirant
That was a small part of my question that was answered - but not the question involving the core issue - which is why the ports won't forward, and how to fix it so they do.
- StephenBJan 27, 2017Guru - Experienced User
What device is between the router and the ISP network?
- evmooreFeb 21, 2017Aspirant
You're referring to the modem? Arris 6183
- StephenBFeb 21, 2017Guru - Experienced User
Yes. I wanted to confirm that it wasn't a gateway (which it isn't).
Also, does the router's internet IP address look like 100.x.x.x?
192.168.x.x, 10.x.x.x, 172.16.x.x - 172.31.x.x are all private addresses (and you'd see one of those if you were using a gateway).
100.x.x.x isn't exactly private, but it is reserved for Carrier NAT, so it's not a public internet address either.
