evmoore
Jan 25, 2017Aspirant
Port Forwarding Problems on Netgear Nighthawk R6700
I've been trying to forward ports on my Netgear R6700. V1.0.1.16_10.0.30 I have an Arris 6183 modem. After playing around for several hours last night I managed to get it to work, but I had t...
- Feb 23, 2017
I managed to get the ports forwarded in the past few ago (finally). Thanks everyone for the assistance.
evmoore
Jan 26, 2017Aspirant
That was a small part of my question that was answered - but not the question involving the core issue - which is why the ports won't forward, and how to fix it so they do.
Jan 27, 2017Guru - Experienced User
What device is between the router and the ISP network?
- evmooreFeb 21, 2017Aspirant
You're referring to the modem? Arris 6183
- StephenBFeb 21, 2017Guru - Experienced User
Yes. I wanted to confirm that it wasn't a gateway (which it isn't).
Also, does the router's internet IP address look like 100.x.x.x?
192.168.x.x, 10.x.x.x, 172.16.x.x - 172.31.x.x are all private addresses (and you'd see one of those if you were using a gateway).
100.x.x.x isn't exactly private, but it is reserved for Carrier NAT, so it's not a public internet address either.
Where am I supposed to look to see this? I dialed into the Arris modem, but I don't see much listed for configurations.
Under Addresses Tab is says 6c:ca:08:70:58:7c and 10:da:43:8d:07:c4
