artvandelay1
Jan 15, 2022Follower
Port forwarding settings not visible after latests hotfix update
Hi community -
I have a port forwarded for a Wireguard VPN on my home network, and after applying the latest hotfix, the table in Advanced > Advanced Setup > Port Forwarding / Port Triggering is empty.
When I try to forward the same ports I get an error, but I also can't VPN back into the device...
Any ideas for solutions?
1 Reply
what firmware did you install?
have you tried a simple factory reset?
If that doesn't help, you can always downgrade the firmware.
