scouzi66
Dec 22, 2016Aspirant
Port forwarding to a VPN client
I enabled VPN access to my R7000 running the latest formware level. Port forwarding to a VPN client connected does not work. Is this supported? I forward the port to the local IP address provided to ...
- Jan 04, 2017
Hi scouzi66,
If you will use it on a PC, you should use TAP and TUN is for mobile or smartphones.
TUN mode - 12973 (for smartphone)
TAP mode – 12974 (for PC)
JamesGL
Dec 29, 2016NETGEAR Employee Retired
Hi scouzi66,
1. What is the software of your VPN?
2. Where is the VPN server connected?
3. Make sure the port forwarded is the correct port for your VPN.
