scouzi66's avatar
scouzi66
Port forwarding to a VPN client
I enabled VPN access to my R7000 running the latest formware level. Port forwarding to a VPN client connected does not work. Is this supported? I forward the port to the local IP address provided to ...
  • JamesGL's avatar
    JamesGL
    Jan 04, 2017
    Hi scouzi66,
    If you will use it on a PC, you should use TAP and TUN is for mobile or smartphones.
    TUN mode - 12973 (for smartphone)
    TAP mode – 12974 (for PC)
