BigE_1235
Feb 04, 2021Aspirant
Port Forwarding to multiple PC's to play Total Annihilation on STEAM
Is there a way to select multiple PC IP addresses to forward ports to after creating a port forward rule, or do I just have to create multiple rules with the exact same info for each PC IP address?
antinode
Feb 04, 2021Guru
> after creating a port forward rule, [...]
It's impossible/nonsensical to forward one port to multiple
destinations.
> [...] or do I just have to create multiple rules with the exact same
destinations.
- BigE_1235Feb 04, 2021Aspirant
Maybe I need to clearify the situation.
1. I have STEAM on my home theater PC and a laptop.
2. My Son has Steam on his desktop PC and lives in the same home, same home network.
3. My oldest Son lives in another area of the state.
I want to play Total Annihilation Game via STEAM with all three of us.
According to portforward.com, this is the info I needed to do this:
TCP
2300-2400, 27015-27030, 27036-27037, 47624
UDP
2300-2400, 4380, 27000-27031, 27036
Any ideas as to how I get this to work on all PC's involved whether those PC's are on the same local home network or across the internet?
Thanks in advance!
- antinodeFeb 04, 2021Guru
> Any ideas [...]
Not if you can't specify different (external) port numbers for one of
the systems on the LAN.I'm ignorant of the reasons for requiring tens or hundreds of ports
to be forwarded to make this stuff work, or how you might be able to
tell some part of it to use some different set of ports. To me, it all
looks like horrible design, but what do I know?
