jack3585's avatar
jack3585
Port Forwarding
I have two web page servers on my lan. Their IP addresses are reserved. I have port 80 forwarded to one and port 8080 forwarded to the other. I can access both pages on the Lan by enterin the lan IP ...
  • antinode's avatar
    antinode
    Apr 09, 2018
    > Attached is what I have setup for port forwarding.
       Ok.  The obvious problem there is in rule 2: Internal Port 8080.
    > 1. Yes. Both are listening on 80.
       If the web server at "192.168.0.17" is listening at port 80, then
    forwarding to port 8080 there won't work.  What you should have would be
    something like:
          External Port   Internal Port   Internal IP Address
                80              80            192.168.0.23
              8080              80            192.168.0.17
    The internal ports are both 80. because that's the port where each web
    server is listening.  The external ports can be (almost) anything you
    wish.  80 is the default for HTTP (but you get to use it only once as an
    _external_ port), and 8080 is a memorable alternate (which you'll need
    to specify explicitly in a URL, like, say, "http://67.9.xx.xxx:8080").
    > The router will not accept duplicate port numbers.
       That datum might have some value if you revealed what you were trying
    to do, and what happened then, which led you to that conclusion.
    >    When you do what, exactly?  "cannot" is not a useful problem
    > description.  It does not say what you did.  It does not say what
    > happened when you did it.  As usual, showing actual actions with their
    > actual results (error messages, LED indicators, ...) can be more helpful
    > than vague descriptions or interpretations.
       Still my advice.  Always my advice.  It's good advice.
