jack3585
Apr 07, 2018Aspirant
Port Forwarding
I have two web page servers on my lan. Their IP addresses are reserved. I have port 80 forwarded to one and port 8080 forwarded to the other. I can access both pages on the Lan by enterin the lan IP ...
- Apr 09, 2018
> Attached is what I have setup for port forwarding.
Ok. The obvious problem there is in rule 2: Internal Port 8080.
> 1. Yes. Both are listening on 80.
If the web server at "192.168.0.17" is listening at port 80, then
forwarding to port 8080 there won't work. What you should have would be
something like:
External Port Internal Port Internal IP Address
80 80 192.168.0.23
8080 80 192.168.0.17
The internal ports are both 80. because that's the port where each web
server is listening. The external ports can be (almost) anything you
wish. 80 is the default for HTTP (but you get to use it only once as an
_external_ port), and 8080 is a memorable alternate (which you'll need
to specify explicitly in a URL, like, say, "http://67.9.xx.xxx:8080").
> The router will not accept duplicate port numbers.
That datum might have some value if you revealed what you were trying
to do, and what happened then, which led you to that conclusion.
> When you do what, exactly? "cannot" is not a useful problem
> description. It does not say what you did. It does not say what
> happened when you did it. As usual, showing actual actions with their
> actual results (error messages, LED indicators, ...) can be more helpful
> than vague descriptions or interpretations.
Still my advice. Always my advice. It's good advice.
antinode
Apr 09, 2018Guru
something like:
80 80 192.168.0.23
jack3585
Apr 09, 2018Aspirant
Thanks for all the help. Using 8080 for the external port and 80 for the internal port solved the problem.
