Risinger
Dec 06, 2022Tutor
Port mapping
I need help as a novice to connect my desktop to my mobile dvr. I am using a r9600v2 net gear. I need to map the following ports 8101, 9001, and 9010. I need to do this in order that I can connect my...
Dec 07, 2022Guru - Experienced User
https://kb.netgear.com/24295/What-is-port-triggering
https://kb.netgear.com/000038518/How-do-I-enable-port-triggering-on-my-NETGEAR-router
https://kb.netgear.com/20917/What-is-port-forwarding
https://kb.netgear.com/24291/How-do-I-edit-a-port-forwarding-service-entry-on-my-NETGEAR-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
