systemsguy54
Nov 29, 2020Guide
Port Scanning by Comcast
Recenty switched my home phone from Comcast to another company (1-VOIP). Everything was fine until my old number was ported from Comcast. Since that finalized, I have been receiving really strange, y...
Nov 29, 2020Guru - Experienced User
You have the C7100V?
I wasn't aware that modem/router/voice device was compatible with any other isp (for phone) other than comcast. That might be causing your issues if its not approved by your ISP.
- systemsguy54Nov 29, 2020Guide
You are correct, they are not compatible. Tehy sent a device that connects through the wired ethernet connection. I think I may have figured it out... They gave me two port forwarding services that I had to insert into the router. However, after reviewing it just a bit ago, I noticed that they left the external IP address set to any which might explain what is happening. I changed to a single IP address (hopefully, I got the right one) and while I was able to dial in with my cell phone, no foolsihness yet! Keeping my fingers crossed!
Thanks,
Paul
- plemansNov 29, 2020Guru - Experienced UserHope it fixes it for you!
- systemsguy54Nov 30, 2020Guide
It seems to have worked as I have been able to make outgoing calls and all the ncoming calls have been real! Question now is... I turned off all the firewall features on the router, should I leave them off or turn them back on, even though th issue is resolved?
