systemsguy54
Nov 29, 2020Guide
Port Scanning by Comcast
Recenty switched my home phone from Comcast to another company (1-VOIP). Everything was fine until my old number was ported from Comcast. Since that finalized, I have been receiving really strange, y...
Nov 29, 2020Guru - Experienced User
You have the C7100V?
I wasn't aware that modem/router/voice device was compatible with any other isp (for phone) other than comcast. That might be causing your issues if its not approved by your ISP.
systemsguy54
Nov 29, 2020Guide
You are correct, they are not compatible. Tehy sent a device that connects through the wired ethernet connection. I think I may have figured it out... They gave me two port forwarding services that I had to insert into the router. However, after reviewing it just a bit ago, I noticed that they left the external IP address set to any which might explain what is happening. I changed to a single IP address (hopefully, I got the right one) and while I was able to dial in with my cell phone, no foolsihness yet! Keeping my fingers crossed!
Thanks,
Paul
