Gamer101
Sep 23, 2021Aspirant
Port wont open for my minecraft server
Im having issues with port forwarding my minecraft server to port 25565 i have the server open and i port forwaded both TCP and UDP and allowed everyhting through my firewall i ran the port check too...
- Sep 30, 2021
i fixed it was just my firewall blocking it
michaelkenward
Sep 24, 2021Guru - Experienced User
That's the second one this week.
It comes up pretty often.
Did you try this in your research:
Search - NETGEAR Communities – minecraft port forwarding
- Gamer101Sep 24, 2021Aspirant
Yes i did and some of them did not help at all
also i have a modem that is seperate from the netgear router
could there be any issue with the modem doing it?
Also should i use Address reservation?
- michaelkenwardSep 24, 2021Guru - Experienced User
Possibly.
What is that modem?
- Gamer101Sep 25, 2021Aspirant
i have a technicolor modem
i am not sure if its causing the issue
