Gamer101
Sep 24, 2021Aspirant
Port wont open for my minecraft server
Im having issues with port forwarding my minecraft server to port 25565 i have the server open and i port forwaded both TCP and UDP and allowed everyhting through my firewall i ran the port check too...
- Sep 30, 2021
i fixed it was just my firewall blocking it
Gamer101
Sep 26, 2021Aspirant
i have a technicolor modem
i am not sure if its causing the issue
michaelkenward
Sep 26, 2021Guru - Experienced User
Sp, we know who made (or sold) tour modem. Sadly, we still don't know what model it is.
Without that information no one can begin to guess if your modem is just a modem or a modem/router.
A web search shows that Technicolor has produced many different devices over the years and quite a few of those are "gateways" which combine modem and router. Irf you have one of those it will almost certainly get in the way of what you are trying to do.
Most bits of kit have a label on them that says what it is, its modem number. Look on the back of yours.
- Gamer101Sep 26, 2021Aspirant
I took a look at the back of the medom and i found the modems model number
model number is TC4400-AM
- michaelkenwardSep 26, 2021Guru - Experienced User
Excellent. Thanks for that.
Unfortunately, it is hard to find anything definitive, so it isn't obvious (from Google) if this is also a router. It says it has two LAN ports in the back, which smells like a router, although it maybe something called "bonded channels", two lines into a router that supports this to get faster Internet.
Other people have also been puzzled by this in the past.
We can't rule out that it is a modem/router, although it doesn't look like one.
Sorry, but that doesn't get us much further.
Thank you ill try to log into the modem and see if there is anything causing a issue
