stoofing
Jan 24, 2019Aspirant
Port wont open
My ports refuse to open even though before port forwarding worked before without the router. I've had this router for a few weeks now, and when I go to port forward on both my modem, which is an Xfin...
- Jan 24, 2019
I had my friends join the server, and they couldn't join. But I did try the test sites a few times without having something use the port so I'll try again.
schumaku
Jan 24, 2019Guru - Experienced User
stoofing wrote:
... and when I go to port forward on both my modem, which is an Xfinity modem and my router, the R6900v2 the ports will not open. I've tried opening the ports on both, on each one individually, and a lot more but the port always refuses to open. ...
Reads like two NAT routers in the data path - the Xfinity modem (also a router typically), and the Netgear router.
A little bit tricky doing the set-up and the port forwarding properly. First you have to ensure the Xfinity does always issue the same WAN/Internet IP to the Netgear router, then do the port forwarding on the Xfinity to the Netgear WAN/Internet IP, and now also the game system on the LAN (which has to be on the same LAN IP always), and then forward the port on the Netgear to that LAN IP.
