opdoom603
Apr 10, 2022Tutor
Portforwarding a Minecraft Server
Recently 2 weeks ago I had to get a new router because my house was getting Fiber installed. I already located the Port Forwarding section on my routers webpage and tried to port forward my Minec...
Apr 11, 2022Guru - Experienced User
What model NG router do you have?
Is uPnP disabled?
opdoom603
Apr 13, 2022Tutor
Sorry for the late response, I appreciate for you responding.
My Netgear router I have is a: R8000P | Nighthawk X6S AC4000 Tri Band WiFi Router
The current firmware I have installed is: V1.4.2.84_1.3.42
I think I got the model number but I'm too sure because I'm very new to this, I use FiberCast and the only thing I found related to a number is this: FiberCast HG8321R
UPnP is enabled
If you have any solutions I would be most grateful.
