opdoom603
Apr 10, 2022Tutor
Portforwarding a Minecraft Server
Recently 2 weeks ago I had to get a new router because my house was getting Fiber installed. I already located the Port Forwarding section on my routers webpage and tried to port forward my Minec...
Apr 11, 2022Guru - Experienced User
What model NG router do you have?
Is uPnP disabled?
opdoom603
Apr 13, 2022Tutor
I feel like I forgot to mention, I already passed the port through the fire wall inbound & outbound settings they both have a TCP & UDP service for the Minecraft Server with 25565 ports set, and that was most peoples solutions to why it wasn't working, but it worked with my old router with no settings changed, only in the port forwarding section. I thought a clean switch over to a completely new router system would work but apparently not. I really hope its not my FiberCast box thats causing the problem.
