deef
May 12, 2017Aspirant
Portfowarding on R7000
Portforwarding is not working with Ziggo Connect box
- May 12, 2017
I resetted the modem And router. Now its working.
thanks for Your support.
May 12, 2017Guru - Experienced User
What is your ISP?
What is your ISP modem mfr and model#
If your using PF configurations, be sure to disable uPnP.
- deefMay 12, 2017Aspirant
ISP = ZIGGO
ZIGGO Connect Box
How can i call the dutch helpdesk???
- FURRYe38May 12, 2017Guru - Experienced User
Need to find out if your ISP Modem has a built in router or not. If not, then the R7000 should work well with out any configurations needed if you leave uPnP enabled.
From what I can tell, I think your modem has a built in router:
https://www.ziggo.nl/klantenservice/wifi/modem/connect-box/
I'd see if this unit has a DMZ and put the R7000s WAN port IP address in to the modems DMZ.
Might check with your ISP to see if this modem can be fully bridged. If not, use the DMZ option above.
My ISP modem has a router, but i deactivated it.
So i use my netgear as router.
