deefAspirantMay 12, 2017SolvedPortfowarding on R7000 Portforwarding is not working with Ziggo Connect box deef to FURRYe38May 12, 2017I resetted the modem And router. Now its working.thanks for Your support.
deefAspirantMay 12, 2017My ISP modem has a router, but i deactivated it.So i use my netgear as router.
FURRYe38Guru - Experienced User to deefMay 12, 2017What is the IP address the R7000 is getting on the WAN port?
deefAspirant to FURRYe38May 12, 2017I resetted the modem And router. Now its working.thanks for Your support.FURRYe38Guru - Experienced User to deefMay 12, 2017Good Luck.
