KH0608
Dec 19, 2018Aspirant
Ports 465 and 587 closed
I have a Nighthawk R7000 Router that has been functioning great. All firmware has been updated and is current. But recently added a Lorex security camera system that has the capability to send out ema...
- Dec 19, 2018
I guess I would try again to configure a custom email server configuration. If you are using Gmail, for example, below are the SMTP settings. I would try port 587 first and 465 second. I would set encryption to required. If you are set up with two-factor authentication on your Gmail account, you will have to go to Google Account -> Security -> App Passwords and create an Application Specific Password that you will then enter in the password box of the Lorex SMTP configuration. The Receiver# address is the email account to which you want the alert delivered.
Outgoing Mail (SMTP) Server smtp.gmail.com
Requires SSL: Yes
Requires TLS: Yes (if available)
Requires Authentication: Yes
Port for SSL: 465
Port for TLS/STARTTLS: 587
