Myiah
Apr 06, 2021Aspirant
Ports Closing on Netgear Nighthawk X8
Hi. I have an Nighthawk X8. I have port forwarding setup on the router along with static ip address saved for different devices on the network. We also use filemaker remotely. Every so often I ...
antinode
Apr 06, 2021Guru
> Model: R8300|Nighthawk X8 AC5000 Smart WiFi Router
Is that accurate? Firmware version? Connected to what? (Some kind
of modem or ONT, or another router, or what?)
For the usual problems with port forwarding, see:
Myiah
Apr 07, 2021Aspirant
We are connected to filemaker remotely on port 5003
We can connect just fine. Its just every so often we have to reboot the rooter because the port closes and we cannot connect.
But once we reboot the router we can connect again.
Hope that makes sense
