McFunk
Oct 24, 2021Follower
Ports won't open. RAX45
Hi all. I am trying to do port forwarding on my new router. The router we took out had this port forwarded and was letting the traffic in but was restarting constantly so we had to replace it. I went...
- Oct 24, 2021
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Be sure to include your ISP modem brand and model#.
Check the user manual for the router for information regarding Port Forwarding information.
Thank you.
Oct 24, 2021Guru - Experienced User
