daniel0615
Feb 29, 2016Tutor
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
- Mar 08, 2016
Hi daniel0615,
I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
JamesGL
Mar 01, 2016NETGEAR Employee Retired
Hi daniel0615,
Do you get the same problem after resetting the router to factory default and reconfigure it manually?
- daniel0615Mar 01, 2016Tutor
Yes, the same.
- JamesGLMar 02, 2016NETGEAR Employee Retired
Hi daniel0615,
Let me check on this issue you have reported. For now, you may try reverting to v1.0.4.30 firmware or check other browser.
- daniel0615Mar 02, 2016Tutor
tried with IE & Chrome, the same!
- 01RMar 03, 2016Luminary
i have a idea please if you are working on the firmware go get an xbox one and play gta online for days and have yr ip be ipv6 only the xbox one will be using 2 ipv6 addreses for DNS it wont use ipv4 at all and see what happens
- thelemonkidMar 04, 2016Luminary
No problem here.
- JimLSMar 04, 2016Aspirant
Just installed V1.0.6.40_1.1.90 and everything is working great. My only problem, as always, when I reset the R7000 with the new firmware, I loose remote connection to the router in my IOS iPhone Genie app. It shows the R7000 but says it's off line. Have deleted and reinstalled the app, but no luck. Kind of sucks. Useing WIFI works fine.
