daniel0615
Feb 29, 2016Tutor
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
- Mar 08, 2016
Hi daniel0615,
I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
BOZGBOZG
Mar 01, 2016Star
Same issue here after resetting the router.
