daniel0615
Feb 29, 2016Tutor
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
- Mar 08, 2016
Hi daniel0615,
I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
daniel0615
Mar 01, 2016Tutor
Yes, the same.
JamesGL
Mar 02, 2016NETGEAR Employee Retired
Hi daniel0615,
Let me check on this issue you have reported. For now, you may try reverting to v1.0.4.30 firmware or check other browser.
- daniel0615Mar 02, 2016Tutor
tried with IE & Chrome, the same!
- replyMar 07, 2016Guide
Could you check thus beta ver is fixed android (opnvpn) connection problem?
Thanks
Please add wol on this router or allow a feature i can telnet the router.
- JimLSMar 07, 2016Aspirant
It works great with IOS OpnVpn. Don't know about Android.
Thanks
Thanks. My mobile is android . So i need android need to be fix.
However. I am not sure are they correct this problem on beta ver.
I think i had mentioned my ptoblem.
Thanks all
