daniel0615
Feb 29, 2016Tutor
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
- Mar 08, 2016
Hi daniel0615,
I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
thelemonkid
Mar 04, 2016Luminary
No problem here.
JimLS
Mar 04, 2016Aspirant
Just installed V1.0.6.40_1.1.90 and everything is working great. My only problem, as always, when I reset the R7000 with the new firmware, I loose remote connection to the router in my IOS iPhone Genie app. It shows the R7000 but says it's off line. Have deleted and reinstalled the app, but no luck. Kind of sucks. Useing WIFI works fine.
- Wolf_666Mar 05, 2016Luminary
Installed and working fine, I did not reset to factory defaults, I never did it and I did not have any problem.
My R7000 is acting as pure AP connected to another Router/Firewall running pfSense.
