daniel0615
Feb 29, 2016Tutor
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
- Mar 08, 2016
Hi daniel0615,
I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
reply
Mar 07, 2016Guide
Thanks. My mobile is android . So i need android need to be fix.
However. I am not sure are they correct this problem on beta ver.
I think i had mentioned my ptoblem.
Thanks all
JamesGL
Mar 08, 2016NETGEAR Employee Retired
Hi daniel0615,
- daniel0615Mar 13, 2016Tutor
Thanks everyone, I disabled the popup blocker on chrome, and it works fine.
- JamesGLMar 13, 2016NETGEAR Employee Retired
HI daniel0615,
Glad to know it works now.
