73Tiger06
Jan 29, 2021Tutor
Possible new Modem and 3 routers
I am pretty new to this and just want guidance but want to go with Netgear. I am pretty handy. Know plumbing, electrical and all that stuff. What I dont understand is all the stuff involved in setti...
Jan 30, 2021Guru - Experienced User
for the average user, they can only use port 1 (or port 1 and 2 if using port aggregation) in the cm1150v. Most isp's (comcast, cox, spectrum) only allow 1 public ip address per modem. so unless you're on a business class line or pay for extra public ip address, you can only connect 1 device to the cm1150v. The reason I recommended it to you was you saying you needed voice. Otherwise I'd have recommended a different modem.
so you'd need to go:
Modem----->router---->devices/switch and then whatever combination of devices you'd like.
hardwiring in access points is the best route you can choose. It tends to have the best throughput.
good working running all the ethernet before hand!
73Tiger06
Jan 30, 2021Tutor
Ijust read your answer from 7:10 this morning. But I added in some things a few minutes ago that were specific to the AX1800 MK63 and my saltellites would be backhauled. Am I ok. I am a 68 year old retired guy just learning. Please be patient with me. I am starting to understand.
