vemnox
Apr 02, 2018Aspirant
Power Adapter that Came With Netgear R7500-200NAS Nighthawk X4
I recently moved homes and a lot of plugs for my electronics got mixed up. My Netgear R7500-200NAS Nighthawk X4 worked perfect in my old house but reboots constantly in my new house. Before I send ...
- Apr 02, 2018
> This appears to match, but the next part does not:
That's the part that matters.
> Could this mean I have the wrong one?
Yes, it's the wrong one.
antinode
Apr 02, 2018Guru
> My Netgear R7500-200NAS Nighthawk X4 [...]
I'll guess that the actual model number, as seen on the product label
(along with the power requirements for the device) would be "R7500v2".
> Output: +12V - 1A
Those lines (not a hyphen, "-") are supposed to suggest "DC".
> Can anyone tell me if this is the right one? [...]
Yes, anyone can. Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Look
for "Technical Specifications", where you should see the specs for the
"Power adapter", which should agree with what's on the product label:
All regions (output): 12V/3.5A DC output
Note: 3.5A > 1A.
> [...] The one I have plugged now should be the one that goes to it;
Perhaps, but it's not.
vemnox
I looked it up as you suggested:
Power adapter • North America: 100-240V, 50/60 Hz input
My adapter, as mentioned previously, shows +12V/1A. Could this mean I have the wrong one?
- antinodeApr 02, 2018Guru
Yes, it's the wrong one.- vemnoxApr 02, 2018Aspirant
Is there a place to get an "official" replacement?
I believe that Netgear doesn't sell them. Ebay? A local electronics
store may have a generic replacement. Just make sure about 12VDC and
(at least) 3.5A. And the connectors, of course.
If you had the right one before the move, then it could be attached
to some other 12V gizmo (where it's probably living an easy life).
There's some value in labeling these things when they're new, before
they get separated from their respective appliances.
