monashaker
Dec 09, 2020Aspirant
Power Button is in solid amber
Hello, My Wifi extender is having the power button in solid amber. I tried to make a factory reset and I am not able to do that. It seems that it stuck on reboot and I don't know what should...
monashaker
Dec 10, 2020Aspirant
Thanks for your response but it didn't work as well
Here is the output, It refuse the connection
C:\Users\m\Desktop>tftp -i 192.168.1.1 put EX3700_EX3800-V1.0.0.84_1.0.56.chk
Connect request failed
michaelkenward
Dec 10, 2020Guru - Experienced User
Keep trying. TFTP is not the easiest of moves. It can take a few efforts and you have to be careful to get everything absolutely right.
Timing seems to be important.
