mjeeda
Apr 03, 2018Aspirant
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone after that my router is Power LED Is Blinking and no wifi i was on version 10.0.2.36 Thank you.
- Apr 12, 2018
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
TorkilH
Apr 04, 2018Aspirant
Got the same problem. :-(
