mjeeda
Apr 03, 2018Aspirant
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone after that my router is Power LED Is Blinking and no wifi i was on version 10.0.2.36 Thank you.
- Apr 12, 2018
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
Apr 04, 2018Guru - Experienced User
Try a Factory reset on the router and setup from scratch...
avtella
Apr 04, 2018Prodigy
You may need to do a tftp flash with the latest firmware or older one if you want. I posted detailed instructions on how but the forum decided it needs to be moderated for some reason.
Just follow these instructions:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034
