mjeeda
Apr 03, 2018Aspirant
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone after that my router is Power LED Is Blinking and no wifi i was on version 10.0.2.36 Thank you.
- Apr 12, 2018
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
Apr 04, 2018Guru - Experienced User
Theres this FAQ:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Hopefully a factory reset is all thats needed.
