mjeeda's avatar
mjeeda
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone after that my router is Power LED Is Blinking and no wifi i was on version 10.0.2.36 Thank you.
  • avtella's avatar
    avtella
    Apr 12, 2018
    No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
    If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
