mjeeda
Apr 03, 2018Aspirant
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone after that my router is Power LED Is Blinking and no wifi i was on version 10.0.2.36 Thank you.
- Apr 12, 2018
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
avtella
Apr 04, 2018Prodigy
You may need to do a tftp flash with the latest firmware or older one if you want. I posted detailed instructions on how but the forum decided it needs to be moderated for some reason.
Just follow these instructions:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-softbricked/td-p/414034
mjeeda
Apr 05, 2018Aspirant
- JamesGLApr 09, 2018NETGEAR Employee Retired
Hi mjeeda,
Did it work for you?
- mjeedaApr 10, 2018AspirantNo
- JamesGLApr 11, 2018NETGEAR Employee Retired
Hi mjeeda,
Have you tried the TFTP using the software?
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
- boby7Apr 12, 2018Aspirant
I don't want to be too smart, I am new here but...
Do You think that tftp syntax on the attached by mjeeda screen is ok?
