mjeeda
Apr 03, 2018Aspirant
Power LED is blinking R7800
Hi, today i update my router R7800 from app on iphone after that my router is Power LED Is Blinking and no wifi i was on version 10.0.2.36 Thank you.
- Apr 12, 2018
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
boby7
Apr 12, 2018Aspirant
I don't want to be too smart, I am new here but...
Do You think that tftp syntax on the attached by mjeeda screen is ok?
avtella
Apr 12, 2018Prodigy
