kanjerwens
Oct 06, 2021Aspirant
Power LED stays amber
What should I do if the Power LED on my Nighthawk router stays amber and does not light white? Also power off and on again don't fix it.
Oct 06, 2021Guru - Experienced User
Try a different power supply?
kanjerwens
No but I'm going to try this. Thank you.
- FURRYe38Oct 06, 2021Guru - Experienced User
Also try a reset, press the reset button for 15 seconds then release...
- kanjerwensOct 06, 2021Aspirant
Nope the reset does not work, look like its not working the resetbutton
Ok, hopefully a different power supply may fix. If not, then the router is busted. :smileyembarrassed:
