kanjerwens
Oct 06, 2021Aspirant
Power LED stays amber
What should I do if the Power LED on my Nighthawk router stays amber and does not light white? Also power off and on again don't fix it.
kanjerwens
No but I'm going to try this. Thank you.
Oct 06, 2021Guru - Experienced User
Also try a reset, press the reset button for 15 seconds then release...
- kanjerwensOct 06, 2021Aspirant
Nope the reset does not work, look like its not working the resetbutton
- FURRYe38Oct 06, 2021Guru - Experienced User
Ok, hopefully a different power supply may fix. If not, then the router is busted. :smileyembarrassed:
