juliacleary
Aug 21, 2021Aspirant
Power light blinking, cant reset, cant get support EX6250
Power light is constantly blinking, noticed we dont get wifi where we need it anymore. Cant do a factory reset, I also cant log into the router even with the trouble shooting help. the night hawk app...
Aug 21, 2021Guru - Experienced User
Is this a new device? (checking to see if you're within warranty or not)
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
juliacleary
Hey, yes only bought it in April so well within warranty. Do you think I should return it? I have a Mac PC but have an android so could do this from my phone right?
