Jrzydvl
Aug 03, 2022Aspirant
Power outage causes me to login to router
I have a NIghthawk X4 AC2350 Smart WiFi Router. After a power outage or shutting off the router I get the login screen: User Name, PWD, 2 security questions. Gotta answer them all. This is very f...
Aug 03, 2022Guru - Experienced User
What model NG router do you have? R####? AC2350 isn't a model #.
- JrzydvlAug 03, 2022Aspirant
R7500
What Firmware version is currently loaded? Don't know. It's currently at moms house.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Verizon DSL
Also happened on my system. Xfinity with Arris SurfBoard 6190
Has a factory reset and setup from scratch been performed since last FW update? No. I should see if a FW update is available.
