sdsexton
Oct 26, 2021Aspirant
Power Surge with NIghthawk AC2300 model: R7000P
Power surge yesterday. Netgear router turns ons, but does not produce wifi connection (i.e. no SSID showing up on devices). Connected to cable modem. Everything else works fine - I hooked up a...
Oct 26, 2021Guru - Experienced User
Try a different power adapter with same volts and amps.
Factory reset the router by pressing the reset button for 10 seconds then release and setup from scratch.
sdsexton
Oct 27, 2021Aspirant
Thank you for the reply.
1) I tried a different power adpapter - did not resolve the problem
2) I did factory reset, but I cannot even get into the router setup any longer via a browser (http://www.routerlogin.net)
- FURRYe38Oct 27, 2021Guru - Experienced User
Does 192.168.1.1 work to access the routers web page?
If not and the recover mode mentioned by plemans doesn't work, I would presume the router is busted. :smileysad:
- sdsextonOct 29, 2021Aspirant
Thanks Plemans and FURRYe38 for your help. I tried connecting via 192.168.1.1 and it just times out (again, I can connnect that way to my 10 year old Netgear router - which I using temporariliy now)
I guess I need to buy a new one (and a new surge protector). I looked at reviews and the model I'm having issues with still seems to be very highly rated, so I might end up re-buying somehting similiar (the AC2400)
Thanks again for your help.
- FURRYe38Oct 29, 2021Guru - Experienced User
Sounds like it's a bust. TIme for something new. :smileywink:
