rpb006's avatar
rpb006
Follower
Apr 03, 2021
Power up R7800 with PoE
Is it possible to use a PoE device to powerup the R7800 router, so I can remove the powersupply of the Router itself?
  • plemans's avatar
    Apr 03, 2021
    the R7800 doesn't have the capability to be ran over POE.
    I've see POE adapters that let you seperate out power but they're usaully fairly low powered. Potentially you could find a set that could power it.
