Eddy0406
Oct 11, 2018Aspirant
Power white Light blinking after firmware update
Hello,
I was doing the firmware update from 0.9.34 to the 0.9.42 and since then the power light on the router started blinking. I did the reset by pressing the reset botton 30 second and plug in po...
- Oct 11, 2018
> I was doing the firmware update from 0.9.34 to the 0.9.42 [...]
"doing" how, exactly? "0.9.34" or "1.0.9.34" (and so on)?
> [...[ I did the reset by pressing the reset botton 30 second and plug
> in power back and no luck.
Not a clear description of what you did, or what happened when you
did it. I'd expect the reset button to have a greater effect when the
router is not powered off.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Factory Settings".
You may be a candidate for the TFTP recovery scheme. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1622096
myersw
Oct 12, 2018Master
If the r7000 is within return window do it. Get something else from a different manufacturer as Netgear does not seem to be able to put out a good firmware build for any of the popular routers right now. They used to be solid vendor and my go to, now I stay away from and have sold my r8000 and r8000p and moved on to different vendor.
antinode
Oct 12, 2018Guru
> example:
Still true.
- Eddy0406Oct 13, 2018Aspirant
Thank you antinode,
It did work with your last suggestion. The router is back and running fine.
