jcarota
Nov 28, 2020Aspirant
Pre-Owned Nighthawk Router unable to access routerlogin.net
Hello, I purchased a pre-owned RAX50 Nighthawk AX6 AX5400 6-stream router from Amazon. I am attempting to do port forwarding and I cannot log in to routerlogin.net with the default username/passw...
- Nov 29, 2020
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
How do I reset my Orbi WiFi System to factory default settings? | Answer | NETGEAR Support
The manuals are also a good place to start, visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware. Search for "factory reset".
antinode
Nov 28, 2020Guru
> [...] any tips on what I could do to factory reset to default
> username/password?
Here's a radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory
Settings". Further reading might not hurt, either.
- jcarotaNov 28, 2020Aspirant
Link not working. Could you please help further?
Thanks in advance!
- antinodeNov 28, 2020Guru
Which "Link"? Which kind of "not working"?
"not working" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.- jcarotaNov 29, 2020AspirantI was assuming it had previously been factory reset since it was a returned item and the actual network name and password were set to default. While scrolling forums that no-one typically cares about until they genuinely want help, try not being such a wiener next time. Other person that replied just posted a real answer, unlike you who mouth-breathes as you touch yourself to your Wikipedia links.
However, I did figure it out after reading your first comment. So, thanks!
