jcarota
Nov 28, 2020Aspirant
Pre-Owned Nighthawk Router unable to access routerlogin.net
Hello, I purchased a pre-owned RAX50 Nighthawk AX6 AX5400 6-stream router from Amazon. I am attempting to do port forwarding and I cannot log in to routerlogin.net with the default username/passw...
- Nov 29, 2020
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
How do I reset my Orbi WiFi System to factory default settings? | Answer | NETGEAR Support
The manuals are also a good place to start, visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware. Search for "factory reset".
michaelkenward
Nov 29, 2020Guru - Experienced User
Support | NETGEAR
