jcarota
Nov 28, 2020Aspirant
Pre-Owned Nighthawk Router unable to access routerlogin.net
Hello, I purchased a pre-owned RAX50 Nighthawk AX6 AX5400 6-stream router from Amazon. I am attempting to do port forwarding and I cannot log in to routerlogin.net with the default username/passw...
- Nov 29, 2020
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
How do I reset my Orbi WiFi System to factory default settings? | Answer | NETGEAR Support
The manuals are also a good place to start, visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware. Search for "factory reset".
antinode
Nov 28, 2020Guru
> Link not working. Could you please help further?
Which "Link"? Which kind of "not working"?
"not working" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
jcarota
Nov 29, 2020Aspirant
I was assuming it had previously been factory reset since it was a returned item and the actual network name and password were set to default. While scrolling forums that no-one typically cares about until they genuinely want help, try not being such a wiener next time. Other person that replied just posted a real answer, unlike you who mouth-breathes as you touch yourself to your Wikipedia links.
However, I did figure it out after reading your first comment. So, thanks!
- antinodeNov 29, 2020Guru
> [...] try not being such a wiener next time. [...]
Thanks for your thoughtful criticism. The next time I find myself in
need of advice from someone who's too helpless to find a user manual on
his own, and posts nonsense like "Link not working. Could you please
help further?", I'll try to remember where I might find some.
