Digital999
Feb 05, 2021Luminary
Pre-Sales Help
I am looking for a reverse router/device. Want it to connect via cell network like a hotspot to cell provider. Want it to be positioned outside my LAN. Want it to connect to my 'internal' TP Lin...
Digital999
Feb 06, 2021Luminary
I have an internal LAN -- lots of workstations and devices.
I have a TP-Link load balanceing router -- multiple ports going to the Internet. One is DSL, another is satellite. The router has a load balanceing alogrithim that distributes the internal traffic across the available WAN ports to the Internet.
Internet is hard to get where I am but there are cell towers.
I am looking for a device, like a hotspot, that can connect to a the cell service and in turn connect to the router. It would be another access pathway to the Internet.
It would only have one port going to the Internet router and modem connections to the cell signals governed by the plan that the cell folks offer.
michaelkenward
Feb 06, 2021Guru - Experienced User
Check out this area of the community:
Mobile Routers, Hotspots & Modems
That's where people turn up asking for help to set up the sort of thing you want.
I doubt if you'll find an exact equivalent to what you want, which seems atypical, but there may be a few clues.
- Digital999Feb 06, 2021Luminary
Thank you -- a good suggestion.
