Olafro
May 29, 2020Initiate
Printer Not Detected When Plugged Into USB Port
When I plug my printer into the USB port of my router, the USB light on the router does not go on. And in the router admin page in the ReadyShare section it says, "Status: No USB Drive".
If I plug in a USB flash drive, it is recognized.
Router: R6700v3 Nighthawk AC1750 Smart WiFi Router
Printer: HP Color LaserJet CP1215
Netgear Firmware: V1.0.4.84_10.0.58
I would like to connect the printer to the router so that computers connect can print to it using ReadyShare (as advertised).
Thanks!
- AlwinJoseAspirantFacing the same issue. I am using a windows 10 laptop and an HP 1112 printer. The printer works just fine when connected directly to the computer. When connected to the router the usb light does not flash green. Moreover a USB Flash drive gets detected. Completely lost with this.
> Facing the same issue. [...]
Different printer. Different router model, firmware. What, exactly,
is "the same"? Not every "printer doesn't work" complaint has the same
cause.Start your own thread for your own, different problem.
> [...] Completely lost with this.
More general advice for the lost:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "printer".
Did you do any of that stuff?> [...] When connected to the router the usb light does not flash green.
Not a good sign.- OlafroInitiate
Well, he did remind me that nobody every took a look at my original issue which is still unsolved. I've resorted to using one computer as a printer server that is directly connected to the printer, but that is not the ideal solution.
