stedep
Nov 25, 2020Aspirant
Printing from IOS devices (airprint)
Hello, I recently replaced my cable modem/router with a Netgear Gateway C7800 using Xfinity as a service provider. I don't have a lot of expertise working with this type of equipment. Setup of the m...
michaelkenward
Nov 26, 2020Guru - Experienced User
The usual way to fix wifi printers, if that is what we are talking about, is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
As you have replaced the modem, you may have to reset the printer to its defaults and set it up again from scratch.
- stedepNov 27, 2020Aspirant
Morning, Thanks for the response back. I reset printer to factory defaults and reconfigured device for wifi and WPS connection. When i initiate a print request, say from an IPAD, IOS device sees printer (Epson XP-640 series). Message "printer offline" appears. Just for the sake of not knowing what else to try, i logged into the router and changed the channel frequency (2.4Ghz) to another channel, low and behold the print request completed! Initiated another print request (from IOS device), same "printer offline" message appears. Really not sure what this does or does not indicate. Anyway, appreciate the advise....Steve
- BeeDawgApr 21, 2021Aspirant
I got Airprint to work on my Brother MFC-J5945DW by disabling IPv6 under Network>Protocol>AirPrint>Advanced Settings>IPv6.
