TheComputerHyp
Dec 01, 2021Guide
Priority alwaystatus?
When viewing my "Attached devices", their Priority always shows as "low". If I edit the device and change its priority, then return to "Attached devices", its priority will still show "Low". But if I...
michaelkenward
Dec 02, 2021Guru - Experienced User
Where are you looking. There are various places where you can view Attached devices.
And your hardware is?
- TheComputerHypDec 02, 2021Guide
"Priority" ALWAYS shows as "Low" in Advanced tab/Administration/Attached Devices.
However, when I go to edit a device on which I have previously set the priority to "Normal", the status shows as "Normal" in "Edit Device" but shows as "Low" when I return to Advanced tab/Administration/Attached Devices.
Router: RAX75
OS: Win 11 Pro
