Firecapt
May 08, 2022Aspirant
Problem after firmware update
After updating to the latest firmware, I'm having trouble loading many websites. The browser window says it can't connect, but after pressing "try again" a couple of times the website finally loads....
May 08, 2022Guru - Experienced User
Did you factory reset and setup from scratch after the last FW update?
Try enabling IPv6 on the router...
Firecapt
May 09, 2022Aspirant
Thanks FURRYe38,
The switch to IPv6 seems to have resolved the issue. If the problem resurfaces I'll repost, but for now all appears to be well.
Thanks again đ
- FURRYe38May 09, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
